It is currently Mon Aug 18, 2025 10:43 am
 Post subject: Neck angle
PostPosted: Mon Jun 30, 2014 4:18 pm
First name: Rahoul
Last Name: waghmare
City: pune
State: maharashtra
Zip/Postal Code: 411044
Country: india
Hello friends
today before attaching fretboard to the neck i check the neck angle,
the neck angle is perfect but one problem is that the fretboard is not flat on the upper side of sound hole. i checked it with scale and found that the fretboard is about 2 mm high..
is it ok and should i glue the fretboard to the body?
or it should be flush (flat)
also how much should be the distance from soundboard near the bridge without glueing the fretboard?3
waiting for ur advices.
thanks in advance
 Post subject: Re: Neck angle
PostPosted: Mon Jun 30, 2014 5:28 pm
Last Name: Russell
State: Michigan USA
This has been discussed in a number of threads here and many other places. Rather than repeating what has already been discussed have a read through this:
http://luthiersforum.com/forum/viewtopic.php?f=10101&t=43634
Or this:
http://luthiersforum.com/forum/viewtopic.php?f=10101&t=43545
Or maybe this:
http://luthiersforum.com/forum/viewtopic.php?f=10101&t=43491
or Here
http://luthiersforum.com/forum/viewtopic.php?f=10101&t=43447
I am sure there are many more threads here on the forum that can help you with your question.
If you are still unsure about what you are trying to do then let us know and I am sure someone will be happy to help if you have exhausted all the threads.
The search function works OK on this forum but you have to use all the options to narrow down exactly what you are looking for. You can't just type in a question like you would on Google.
Hope these help.
Cheers,
Bob
PostPosted: Tue Jul 01, 2014 11:43 am
A picture would help. Are you saying that the fretboard itself curls upwards, since the neck angle is good?
Old growth, shmold growth!
Users browsing this forum: dofthesea, TimAllen and 10 guests
